SCHOTT SYSTEME
Software Developer for CAD/CAM + IT
SCHOTT SYSTEME GmbH to Present Version 3.10 of its Proven CAD/CAM software at AMB 2022
On the AMB (Stuttgart, September 13-17, 2022), German software manufacturer SCHOTT SYSTEME GmbH are to demonstrate the significant performance enhancements of version 3.10 of their Pictures by PC-CAD/CAM software.
Automated Milling
Small batch sizes, increasing cost pressures and staff shortages nowadays require a higher degree of automation of classical CNC processes. The new software release from SCHOTT SYSTEME GmbH focusses on this with its CAMsmart technology, automating the manufacturing process for multi-sided machining of typical, prismatic workpieces.
The process begins with the construction or import of the 3D CAD volume model (usually via STEP or IGES, VEC and VCZ). The part, which may come supplied in any number of different orientations, is then aligned ready for production. This is followed by the geometric analysis of the workpiece, in which typical, multi-sided 2.5D or 3D milling and drilling features are identified. Appropriate CAM strategies are then assigned to these so that the part can then be manufactured on the machine (e.g., facing, contouring, pocket milling, chamfering, drilling, edge rounding). All of the above-mentioned steps run automatically, but can be modified or supplemented at any time by experienced users.
Use of New Tool Forms
In the new 3.10 version, user-defined tool shapes (e.g. parabolic cutters, barrel cutters, concave radius cutters, etc.) can now be defined using a 2D sketch (e.g. DXF) and used on 3- to 5-axis milling machines.
For example, parabolic or multi-radius milling cutters considerably improve the machining of steep and flat areas, as the larger radii curvature of the milling cutter facilitates larger tool path stepover distances compared to conventional spherical or torus milling cutters, while maintaining the same surface roughness. This leads to a reduction in the number of tool paths, a reduction in machining time and an increase in tool life while maintaining the same surface quality.
Enhanced Machining of Plate Material
In the case of components in sheet material, in order to keep the parts in position when machining, the milling contours now include tags, which can then be separated with a second operation using a number of differing methods. The user has full control over the tag position (manual or automatic placement), length and height etc., as well as the removal method. The machining of contours has also been significantly enhanced, e.g. with more complex approach and milling methods.
Numerous Other Additions
At this point, it would go beyond the scope to explain the large spectrum of all supplementary CAD and CAM functions in detail. Interested readers can see the new functionality for themselves at the SCHOTT SYSTEME GmbH stand at AMB 2022 (Hall C2, Stand 2A01).
With its in-house developed software solutions, SCHOTT SYSTEME GmbH can refer to more than 35 years of product continuity. To date there are no maintenance or support costs charged with the software.
The well-known Schott Systeme motto applies: Software Benefits instead of Software Costs.
Responsable del contenido de esta nota de prensa: SCHOTT SYSTEME GmbH
Solicitud de contacto
Your message
The controller within the meaning of Art. 4(7) GDPR is: IndustryArena GmbH, Katzbergstraße 3, 40764 Langenfeld, Germany.
You may reach our data protection officer under dataprotection@industryarena.com.
Opciones de diseño
  • Título Color de fuente:
  • Contenido Color de fondo:
  • Contenido Color de fuente:
  • Navegación Fondo:
  • Ficha Color de fuente:
  • Enlace Color de fuente:
  • Gráfico de cabecera
Tenga en cuenta:
