611,659 cuentas de miembros
2,290,228 publicaciones en el foro
Registrase aquí GRATIS
IndustryArena Foro > Informática > Software > communication software for FANUC
Resultados 1 al 10 de 10
    Member
    Fecha de Ingreso
    13 May, 16
    Ubicación
    Spain
    Mensajes
    26
    We often use the typical communication software for FANUC I downloaded from http://www.softpedia.com to load/download the programs from the PC.
    http://www.softpedia.com/get/System/...or-FANUC.shtml
    We use this application for all the FANUC CNC but now we have a new machine with FANUC 0i-TF model.
    I set up the IP address: 192.168.1.1 and mask to: 255.255.255.0
    I think FOCAS port number should be 8193 (that is the way we set in other machines).
    Unfortunately I cannot succeed.
    I tried with the RS232C (COM ) connection and It works but prefer to avoid this type of communication (it is slower and less comfortable).
    I use the COM communication only for old CNC where Ethernet is not available.
    Does anyone know how to set up the FANUC 0i-TF CNC for Ethernet connection?.
    Thank you for your help!
    Member
    Fecha de Ingreso
    13 May, 16
    Ubicación
    Spain
    Mensajes
    26
    I’m still using the COMMUNICATION SOFTWARE FOR FANUC CNC , it works very well with all FANUC CNC I have even with old SIEMENS CNC with RS232 connection.
    Now I would like to get rid of cables and use WiFi connection instead.
    This is an old project I have but I do not have experience with wireless connection.
    Has anybody tried to use mentioned software with wireless connection?.
    I downloaded the latest version of "COMMUNICATION SOFTWARE FOR FANUC CNC" from SOFTPEDIA:
    https://www.softpedia.com/get/System...or-FANUC.shtml
    I would really appreciate your help.
    Regards
    Juan Carlos
    Member
    Fecha de Ingreso
    08 Jul, 21
    Mensajes
    thanks for sharing the link with us guys, it helped a lot.kinemaster mods
    Member
    Fecha de Ingreso
    06 Jan, 22
    Mensajes
    9
    Hello!
    Let me invite you to my youtube channel where you will find some solutions to your daily problems, I hope you help us subscribe and share it!
    https://www.youtube.com/watch?v=dcE2oWu9ffM
    Member
    Fecha de Ingreso
    17 Jun, 22
    Mensajes
    Obviously at one point or another, you will need ethernet connection for all kinds of activitiesNulls Brawl APK.
    Member
    Fecha de Ingreso
    04 Dec, 22
    Mensajes
    Cita Iniciado por Dhawad Ver Mensaje
    Keep sharing with us.OGinstagram Apk
    Yeah keep sharing with us, and I am totally agree with on this motive.
    Member
    Fecha de Ingreso
    13 May, 16
    Ubicación
    Spain
    Mensajes
    26
    I downloaded the last version of COMMUNICATION SOFTWARE FOR FANUC CNC (V94.2) from the same link:https://www.softpedia.com/get/System...r-FANUC.shtmlI would recommend trying it, there are nice new features on it!.
    Member
    Fecha de Ingreso
    11 May, 25
    Mensajes
    xcellent topic,Quality communication software is vital to the most efficient operation of FANUC CNC machines. Ease of integration, real-time monitoring, and simplicity of use are among the most important considerations. Software with support for protocols such as FOCAS or MTConnect can truly optimize data exchange and productivity. Excited to learn about solutions to consider. speaker cleaner
    Última edición por james24; 20/05/2025 a las 13:10 PM
    Member
    Fecha de Ingreso
    23 Aug, 25
    Mensajes
    Have you checked if the Ethernet function is actually enabled on the 0i-TF? Some FANUC 0i models require an optional Ethernet board or the FOCAS/Ethernet option to be purchased and activated. On a few of our machines, the port was there but inactive until the option was licensed.
    Also, are you able to ping the control at 192.168.1.1 from your PC? That would at least confirm network-level communication before troubleshooting FOCAS specifically.
    If you can ping but still can’t connect, it might be a port issue—some controls use 8193 for FOCAS and 8192 for the embedded FTP server. Have you tried FTP as a quick test?
    I’d be interested to hear what steps you’ve taken so far to narrow it down—maybe I can try the same on our 0i-MF and compare settingsLightroom Mod APK
    Member
    Fecha de Ingreso
    14 Feb, 26
    Mensajes
    I ran into this on a 0i before.
    First make sure the embedded Ethernet option is actually active on the control. Some 0i-TF units have the port but the FOCAS/Ethernet function is not enabled from factory.
    Try pinging the CNC from your PC to confirm basic network communication. If ping fails, it’s a setting issue. If ping works but FOCAS won’t connect on 8193, check that the Ethernet function is licensed and not blocked by firewall.
    On ours it ended up being the Ethernet option not enabled. Worth checking with the builder.
    NawafPerfumes.com
Permisos de Publicación
  • No puedes responder temas
