02.05.2023
Strategic cooperation with Jonas & Redmann
Liebherr-Verzahntechnik GmbH has agreed on a strategic cooperation with Jonas & Redmann - a specialist in automation solutions of battery cells and modules - to create automation systems. Ir a noticias
18.04.2023
Gear shaping of double helical gears
During gear shaping of double helical gears, the exact positioning of both gears in relation to each other is often very work-intensive. Liebherr-Verzahntechnik GmbH has taken up this challenge and is expanding its technology portfolio for the production of double helical gears. Ir a noticias
13.12.2022
Showroom for the automation of tomorrow
The Kempten Tech-Center of Liebherr Automation Systems provides a space for trials on high-quality automation solutions. The current focus is on vision-based robotics, bin picking, and processes in battery pack assembly for e-mobility. Ir a noticias
29.11.2022
Measurement solutions from a single source in transmission component manufacture
The Chinese Haoneng Group, a leading manufacturer in the field of vehicle transmission synchronization, is operating four WGT series inspection machines from Liebherr-Verzahntechnik GmbH. Ir a noticias
18.10.2022
Smart pallet handling for all requirements
– No such thing as can't
Whether it's a standard product or a major project, Liebherr-Verzahntechnik GmbH offers solutions for the automation of machining centers of any size. The focus is always on the benefit to the customer – whether it's starting out in automation, working with a large, complex system or a special solution.
Ir a noticias
06.09.2022
Gear solutions for e-mobility
New drive technologies in electric mobility are changing the requirements for gears and therefore also for of the quality of the tooth flank surfaces. Manufacturers of gears have to adapt their manufacturing process accordingly. Ir a noticias
24.08.2022
Liebherr automates the assembly of pluggable module connectors
Plug connections for electrical contacting of modules in the battery pack offer several advantages. However, until now it was only possible to assemble them manually – an obstacle for large batch sizes. Ir a noticias
09.08.2022
CNC chamfering with ChamferCut or Flex Chamfer
Chamfering gears prevents the edges of the teeth from becoming brittle during heat treatment and reduces transportation and installation damage. Multiple processes can be chosen for this. Ir a noticias
26.07.2022
Bin picking made easy
“Bin picking” is among the most difficult disciplines in automation. Adjusting the parameters for reliable recognition and gripping of complex objects is demanding and requires expertise. Ir a noticias
12.07.2022
Liebherr Academy goes digital
Everyone’s talking about digital learning – Liebherr shows how it’s done: Training courses on all topics connected with gear technology are now taking place in the form of interactive Live Online Training. Ir a noticias
28.06.2022
Reman starts in Brazil
The Reman used equipment program provides a second lease of life for older, high-quality machines. Since 2016, older machines have been refurbished at locations in Germany and the USA. Now the Reman program is also being launched at the Liebherr site in Brazil.Ir a noticias
14.06.2022
PHS 3000 Allround: The family is complete
With the successful launch of the PHS 3000 Allround pallet handling system, Liebherr’s PHS family is now complete.Ir a noticias
01.06.2022
SECLA – one for (almost) all
Easy operation combined with maximum flexibility and short setup times – these are the features of the clamping arbor SECLA, which Liebherr has been successfully using in its own gear cutting machines for many years. Ir a noticias
17.05.2022
Industrial services of the future
Liebherr is expanding its service portfolio and entering the digital future with extended support solutions. This enables customers to save time and money and to increase their system availability by means of faster response times, at the same time as minimizing the ordering and processing effort. Ir a noticias
19.04.2022
Gear skiving tools: a question of trust
Gear skiving is considerably more productive than gear shaping and more flexible than broaching, but it also has its pitfalls. Minimal errors in tool design can be decisive for the success or failure of the manufacturing process.Ir a noticias
05.04.2022
Innovative automation solutions for e-mobility
In the course of the mobility transition, electric and hybrid drives will gradually replace the traditional combustion engine. The battery is a key element in electrification: More and more manufacturers are starting their own production of battery systems and are looking for suitable solutions to do so. Ir a noticias
23.03.2022
Two become one
Liebherr-Verzahntechnik GmbH has refined its inspection software for gears and combined two steps into one: Chamfer measurement is now integrated into gear measurement.Ir a noticias
07.03.2022
Automated line inputs and outputs
Due to the electrification of automotive fleets, there is no doubt among experts that growth in combustion technology will come to a halt. This will result in increased cost pressure on the current production capacities. Ir a noticias
29.04.2016
Relanzamiento completado de los mundos de productos en liebherr.com
Reanudación de las presentaciones de máquinas de construcción, técnica de trasbordos, técnica de engranajes y sistemas de automatización, así como componentes Ir a noticias
16.12.2015
Una grúa sobre orugas de Liebherr LTR 1060 de la empresa Clausen sube una montaña de 3.000 metros
Para los trabajos de montaje en la estación de montaña de la nueva telesilla de Hirli ha hecho falta una grúa y a una altura de 2.900 metros, en Zermatt. El mayor desafío para la LTR 1060: La subida en senderos no asfaltados.Ir a noticias
02.12.2015
Liebherr VarioBase® facilita la construcción de un puente
En ocho empleos nocturnos se renovó un antiguo puente ferroviario de 110 años en Aarwangen en el cantón de Berna, Suiza. Las dos grúas LTM 1160-5.2 y LTM 1130-5.1 solamente se pudieron estacionar en un estrecho puente de carretera paralelo gracias a la base de apoyo variable VarioBase® desarrollada por Liebherr.Ir a noticias
This website uses cookies
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
